1932 Ford 4 Dr Sedan
kustoms
Nicktown
Pa.
Price
15000.00
For sale 32 ford 4 dr sedan, frame is done except for paint. The chassis has a Pete and Jakes dropped Ibeam front end hair pin mounted with disk brakes and calibers. The brake pedal and dull master cylinder the brakes lines are all bleed and up. The rear is a 8 inch ford with 4 bar mounted with coil over shocks. The xmember is set up for a chevy turbo 350 trans the motor mounts are welded in place for a small block chevy.The steering is a vega box mounted,This is a roller. The body needs finished, has a new floor installed.the doors close great with bair claw latches with new locking door handles on front and non locking on rear doors. The body comes with all 4 fenders rear frame horn covers, running boards, a full set of inside garnish moldings, a new wood kit for the roof, an orignal soft top metal retainers, a new aluminum radator with a new grille shell with stainless insert a full set of inside window garnish moldings running boards front fender braces rear seat springs. email with questions djs3251@verizon.net or call anytime 814-659-1000. Dave
