kiphartzell
I am trying to get my 1932 3W doors better aligned at the latch & dovetails. I have installed new .3125 case hardened door hinge pins and the B pillars are original, straight, and very solid. No play what so ever when trying to move the door up and down at the latch end. Everything looks good at the hinge side, body and door face match well.
With that said, I know the size and weight of the door make the 3W alignment somewhat problematic, but I would like to improve on what I have so far....
Both doors, when making contact with the A-pillar, hit the female dovetails about 1/4-3/8" low. Basically, the male dovetails hit squarely in the middle of the lower lead guide (photos attached). I can lift the doors and the doors will shut, but with no longer having any play in the hinges, I am concerned that this will put unwanted stress on the hinges/B-Pillar.
I believe that I now need to shim the body at the B-pillar to correct the door alignment. I have Wescott's doc on general body shimming, but looking for any tricks/approaches to take. Also, this is a full fender coupe and the rear fenders are already installed which leads me to believe that raising the b-pillars to correct the doors will throw things off with my rear fenders?!? How should I start the shim process? It also looks like the cowl may be a little high since I have some extra space at the lower front hood side panels. I have some 1/8" shim plates and I was going to add a couple to each of the body bolts by the B-Pillar and work from there, but I am open to other approaches. Also, I assume I need to remove the rear fenders first?!? Any help would be appreciated. Thanks.
