1932 Ford 3 speed transmission
Orca62
Hi Just purchased a 1932 Ford 3 speed transmission. I am missing the rear mount and what ever is associated with it. I am going to be using the transmission in a sprint car project so I do not need the rubber mount as I see on online because I do not have a k member in the Model T chassis it will be in. Can I use any rear transmission mount from 32 up ( to what year) that will bolt up to the holes in the back of the case, hold the bearing in and not leak fluid out. I have a 1939 closed driveshaft Ford rear end in the chassis.Thanks for any input.
Hi, I was able to purchase a rear transmission mount from I believe a 1940 Ford. It fits perfectly on the back of the 1932 transmission. This will work for my application. Thanks.
