1932 Flathead Engine
Ingram 33vicky
Sweet Home
OR
Price
$2000.00
Proper engine for a 32.
Block, heads, Pan, intake and exhaust, cam cover, water pumps, fuel pump, generator, all correct for a 32.
The block has had a crack on the inner lower rail. Appears to be properly done. I have pressure tested it and can get an indication of air leak at 25+ pounds pressure.
The internals all appear to be recently done. You can still see the hash-marks from the cyl. hone.
This engine was from, a 32 coupe that was part of the Towe collection in Montana.
My inspection indicates that this engine had minimal running time. One crank bearing has severe wear (replacement bearing too tight) and I believe was the reason that it was removed from the car.
If interested give me a call on my cell phone 541-990-7377. Will deliver within a reasonable distance from Sweet Home, Oregon.
Respectfully, Paul Ingram
