true blue 32 man
- City
- Milw
- State
- WI
- Price
- 500.00
1932 column drop & ignition switch
This is nice original column drop & ignition switch with key that has been cleaned and re-lubed.
Correct Hurd “KB” lock assembly with original Hurd key and extra replacement key.
Original on/off switch bezel with correct original brass drive rivets not the cheap aluminum repo one.
Original tension screw, spring with ball
New correct break off bolt.
On the back is a mint original terminal box, terminal plate is rare “S” and mint original brush.
This column drop has most of the original paint, has some nicks and scratches and would need polishing or use as is or repaint for show quality.
Key lock and switch work perfectly
If you want a mint original this is it!
$500.00
$500.00
