1932 bb won’t go into 3rd or 4th
32forddump
No Matter what I try I can’t get the dump truck into 3 rd or 4 th. Truck has been sitting many years. I have flushed the transmission and added new oil.
Re: 1932 bb won’t go into 3rd or 4th
Can you put in 3rd and try to start out or will it not go into 3rd or 4th at all? It sounds like it will, if you say the shifter is working okay. I assume you know you have to double-clutch to shift that trans, no synchros. If you do not 'match the gears' rpms by double clutching, it will not slip into gear. Does it grind the gears or do nothing at all.
Take the cover off to confirm the rails and forks are moving as should, and if problems are not there then move the gears by hand to see what is stopping them
This^^^^, could be a bit of rust holding up the 3-4 rail in its bore.
Thanks for your comments. The gear for 3rd and fourth was stuck. Truck is cruising now.
Well great! We need some cruising pictures too!
Regards,
Chris and Cheryl
