WRA
I’m working on a B Engine with a Cragar Overhead Valve Assembly. I have installed an FSI Distributor with the extended shaft.
Once at TDC and pointed at #1. I can turn the rotor completely around by hand. When I rotate the engine, the rotor turns.
I have two other B -Engines that are very tired stock running engines. The rotor assembly is rock solid and unable to turn or rotate by hand.
I would guess the Oil Pump Distributor Drive Gear is not fully engaged some how?
Any ideas, thanks
Any ideas, thanks
