1932-1934 Ford "B" engine and trans- runs great!
Chris
Spokane
WA
Price
in add
I am jerking the B engine out of my original 33 Ford pickup. This engine runs very well. It does not smoke at all nor use any water or oil. It drips a very small amount of oil out the rear main when it has run or a while...that is normal. Engine is very tight and does not make any sounds. It DOES have the counterbalanced crank (non pinned type). I have put about 500 miles on it since owning the pickup. It charges and I have had zero problems with it. The carb shown in the pics is an A carb and not included (it is my Dads), but I have several B carbs included that will need to be rebuilt as well as another running A carb (the one that was on it when I got the truck). Engine recenlty tuned up and purrs :D
The 3 speed ****** is VERY tight and shifts unbelievably well. It does not grind or howl. It downshifts very well. I would have no problem tossing this engine and trans into a car/truck and running it. Engine looks new inside, I have not had the tower off the trans but I would guess it looks new as well. Also note the waterpump and front pulley are shorter...33-34 only and very hard to find.
You get the engine, trans and all parts attached on it (except previous noted carb). I am asking 2,000.00 for the set up. I will strap it to a pallet if you need it shipped for free, you arrange the shipping though. I will be pulling it in the next 3-4 weeks...if you wanna come hear it run be my guest. I will post some video of it running soon.
Chris
509-869-0266
hi chris - just saw the add b/4 going to sleep. I will try to call you in the morning, but not too early. I am interested in the package. Do you believe that a single pallet will survive the weight of an engine & trans to chicago? Regards, Steve Hackel 708-687-4183
