1931 wide bed pickup
Los Gatos
CA
Price
6000
Late 1931 Ford Model A wide bed pickup. Truck has the late 31 indented firewall, fabric top cab. Late 31 wide bed. Will need the lower cowl sides and back of cab patched. The bed has some rust in the front of the floor and in the front stake pockets, bed floor also has a long crack from the front to the back from being used without the wood subfloor. Truck runs good, has a factory replacement diamond block model A engine. Engine leaks at the rear main as all Model A's do. Brakes and steering are functional, but truck does not drive due to clutch not working, not sure if it is stuck or just worn out. Truck has 33-34 17" wire wheels and aftermarket BLC headlights. Fenders are a little bit rough, but are all there, have seen worse wide bed rear fenders restored as they are almost impossible to find. Running boards and splash aprons are a little rough as well. Cab, bed, hood, doors, and grille shell are all in decent shape. I have a 1964 title signed by previous owner, and the black license plates match the title. Last registration tag is from 1967. Truck is a good candidate to restore or would make a nice hot rod. Asking $6000 OBO, and willing to knock $200 off if you don't want the engine and I will remove it. More pictures available upon request. If interested call for more information, too many projects forces sale. 408 439-3106
