The Victoria uses the standard Model A tail light bracket on the left.
The right side bracket is a reproduction that Ford never made. I caution you, do not transfer the tail light bracket mounting hole pattern from the left rear fender to the right rear fender.
The reason is that the right side reproduction tail light bracket has a geometry that is not the opposite of the OEM left side bracket. Eyeball the right side tail light into position so that it is equal & opposite of the OEM left side light. Then mark and drill the bracket holes into the right rear fender.
