What are you comparing its uphill performance with? Before it was rebuilt? With other As?
Does fiddling with the GAV make any difference?
If it ain't back firing/ running out of gas then probably fuel supply is good.
If you're absolutely sure the ign timing is OK then the timing is probably good.
Sure you got the manifold gasket nice and no leaks?
As Mitch #4 says check exhaust?
As Newshirt #14 says check throttle fully opens.
If it's running on all 4 cylinders, not misfiring, and idling well, then the ign is probably good.
Having eliminated all the easy things it's time to get in touch with the rebuilders and tell them they have a problem to remedy. (All external things being equal I would suspect valve timing/ cam shaft/ valve lift.)
