1931 Tail Light/brake Light??
reverendjim
Hello,
I have just purchased a 1931 Tudor Sedan. The car had a frame-off restoration a few years ago and had been sitting some. When I picked up the car the cutout was burnt out so I replaced it. The cars runs well but I can't seem to get the tail light or brake light to work. I am getting power but the bulbs will not burn. I thought it might be a ground problem so I took the ground cable loose and sanded the frame but it has not helped. I checked the wiring and it seems to be correct according to the repair manual. What should I try next?
Thanks in advance,
James
If you have power to the bulbs it is more than likely not seeing a ground at the light itself. It could be due to corrosion or the possibility you have fiberglass fenders.
Take a wire and touch it to the base of the bulb and the other end to the bumper. This should provide a ground and the light should light. From there you have to determine why the base of the bulb is not connected to ground.
Tom Endy
I guessed a poor ground was probably going to be the trouble. I will get out there later today and see what I can find. The fender is steel but its all fairly freshly painted so I suppose the paint could be hindering the proper ground.
Thanks So Much,
James
