1931 steering column brace bracket installation in......
Forddan
Hi
I need to install a 1931 steering column brace bracket in my early 1929 Ford Tudor as I have a small gas tank leak to solve.
Anyone have some pictures to share on how to attach/install it.
This is the steering bracket I have to install:
Thank you !!
Daniel
Did you try to see if it fits or can be adapted somehow under the dash rail on your '29 ? That style is used as you state on later cars with 2 tooth steering and bolts to the cross rail mating sections with the dash cover removed for easier access. The projecting pin slips into a recess (hole) in the cross pieces.
