Looking for the correct answer to the question. The model A wheel is held on by 5 lug nuts which center and draws the wheel up to the hub. Question is does the rim of the wheel touch the hub or should there be clearance between the rim and the hub?We are only talking about the center of the wheel where the spokes are attached to the inter part of the wheel-DOSE that rim touch the hub. If so, What is the measurement? how do you measure the distance to see if it is too much or too little?
Thanks
Thanks
