3.6rs
Very complicated matter.why?
we charge in the car all the time
You do not charge a rechargeable flashlight with the light on
Everyone does what he wants, but it's not the way to do it.....
I charge modern car batterys everyday in the car... most have parasitic draws
Alternators in modern cars (or generators in old cars) are calculated on charging a battery in a certain car. Battery chargers are for general use and they can give pulses that are not so good for ecu in your modern car. Charging a connected battery in a Ford A can do some weard things also. (many users of this forum can't even understand why you can measure 6v on some places when teh key is in the off position...)[/COLOR]
Why not?
[/COLOR]
Why not?
Actually Bob, there are several reasons to remove the battery from the car to charge, not least of which is the connection between the charger and the battery are not compromised by any corrosion that could be between the terminals and the post, but also while charging a lead acid battery there are vapors/sulfuric acid fumes that emit from the battery that can eventually eat the paint, primer, and metal beneath that, as well as the upholstery.
So, take the battery out, place it on a couple pieces of wood, hook up the charger and let it run over night.
BTW, NO SMOKING around a charging battery !!!
And this isn't happening when the alternator or generator is charging it
in the car?
Bob
in the car?
Bob
Yes it is Bob, THAT is why the under side of your battery mount is all but destroyed and the battery "box" is in disrepair. It is just not as much as when you hook up a charger, and also only as your motor revs the amount of charge changes where the charger is going to try to boil a charge into the battery for as long as it is hooked up.
zzlegend, I'll be right over and share my recipe for stuffing for that bird since I believe that mig welder is the only way to cook it!
yea, anything placed directly on concrete and the temp fluctuates in the night (like fall and spring) you lift it up in the morning and its soaking wet underneath.Well, since concrete never dries, and water is a great conductor, it gets around to the same theory as being able to now charge your smarter phone without plugging into the charger, just laying it on the pad allows energy to transfer from pad to battery. Even with asphalt this convection can remove some of the charge, not as much as concrete, but still draw from the battery even through the plastic of the battery insulates the bottom. Since air is a decent insulator and wood is a poor conductor, placing on the wood just helps get and keep the charge in the battery.
