1931 ign switch and seat back stop
kurt v
Anyone make the pop out ign switch ,ecklers say they do anyone use their's, or another place to get the pop out switch. I have the housing and cable need the correct switch.
Next, i found the seat back adj for my 31 roadster (top part , package tray )now i need to know what holds the bottom of the back seat in place to keep it from sliding back ?
thanks
kurt
Burt, when you say "back seat" are you referring to the rumble seat or the back cushion of the front seat?
Mine has 3 "L" brackets fastened to the seat riser and 3 bolts from the wood framework on the cushion assembly fastens through holes in the L brackets. Maybe the brackets are missing on yours. Are the bolts in the wooden framework?
Fundytides, found what you have mentioned about the back seat wood, CUBLE offers the wood back support part no 1502, is this what you have?
thanks
kurt
Could be. I never heard of CUBLE. Bratton's has it as part #40160 . You might have to make the l brackets at the bottom if you don't have them the top just fastens to the "seat adjuster". I have an extra set of the wood frame (5 pieces) but I am in Canada and shipping would probably be expensive. If you are going to Hershey in Oct. I could bring them along $60 (never used) if you are interested.
Interesting. I was hoping Bratton’s would have a picture, but no such luck today.
https://www.brattons.com/30-31-ROADSTER-BACKREST-WOOD-FRAME-FOR-SEAT-SPRINGS/productinfo/40160/
Found the wood that i needed, called Brattons and lady told me to call Classic Products in nc (335 691 1344 ) that is where they get their wood.
In stock 85.24 plus ship
thanks for the help on the wood, now for the ign switch.
kurt
