J John Kuhnast Well-known member Aug 15, 2016 #1 Have slight leaking gas valve. The under hood type, Can I polish this up with toothpaste while still in the car? Thanks
Glenn C. Well-known member Aug 15, 2016 #2 Probably, as long as you can ensure no toothpaste gets into either line. If it was me, I would pull the valve, and do a proper job.
B Big hammer Well-known member Aug 15, 2016 #3 If you remove the valve you can then flush the rust from the tank that is making your valve leak. Do it right and many years with no problems
