barnnone51
Trying to put a RPU Together with fenders and running boards .I do have a set
of 31s off a Sedan. Or what would be the correct ones. Thanks
You should have added "if the '31 has a wide bed". If the '31 has the narrow bed the fenders are the same as coupe, roadster.The fronts will fit,as long as your pickup is also a 30-31.The splash aprons are different between the 30-31,but if used as a whole they will fit just fine.The rears are different.The difference is night and day on the rears.
