lotsagas4u
Hello, working on a 31 budd cab pickup, rear roof rib is broken on 1 side, how is the best way to replace this? I have the 6 visor screws removed, as well as the 2 small screws holding the visor. I can lift the roof up a bit. The rear joint looks like a tack strip with a center cover. There are MANY nails coming through the roof, as observed where the broken roof rib is. Thanks for your help.
