1930 Sport Coupe Rear Spring Count
History
Does anyone know what the number of (rear) leafs/leaves is in a stock 1930 sport coupe rear spring set? Thanks
Keep in mind that the original Ford springs had leaves of variable thickness. Modern spring-makers may be able to get the same spring rate with fewer leaves of different thicknesses. For example, Detroit Eaton provides a 10-leaf front spring for Model As to replace the original 12-leaf, and an 8-leaf front spring to replace the original 10-leaf. They do provide an 8-leaf rear for coupes and a 7-leaf rear for roadsters.
If anyone has ready access to Marco Tahtaras' excellent spring chart, would you please post it?
I have a copy of it, word document, 2 pages, but can't post it for some reason, dunno why.
I think that this is what you want, hope it helps :)
The 8 leaf spring is the red line "B"
