1930 side mount spare tire mount
vso737
New member
Hi,
Can anyone furnish a picture or tell me exactly how the base of the mounting bracket mounts on the frame.
I'm installing a LH fender side mount on a 1930 Model A.
Thank you in advance,
Mike
hello mike
i put one on my 1930 tudor
on the frame there are dimples in the frame to drill the holes so it is pre marked when i get home from work i will take a photo for you real simple to do you may have to remove paint to find them
kevin 1930 model a tudor
1923 model t roadster p/u
Trying to reattach spare side mount on 28 tudor. New splash shield have installed; no
previous holes to go by. Need help and/or pictures.
My friend wanted twin side mounts when we restored his pickup. I mounted the splash aprons then used a pencil through the frame mount to scribe the largest circle the pencil would make, then I found the center of the circle and drilled the hole. They came out perfect. I used a hole saw on slow speed.
Try doing a search. Couple of years ago Don Turley posted step by step instructions if I remember correctly.
Paul in CT
