if it is a charge rate issue the batt would be low after shutdown.
otherwise disconnect the headlight buckets from the conduit turn on the lights and retest.
most likely if it went away unplugged its in the connectors or bucket wiring.. you can also try one at a time to narrow it down...
if not ck the other direction /headlight switch etc..
Battery is new and I put it on a trickle charge when not using it. This is something new as it didn't do it a few weeks ago.
Thanks everyone for the suggestions above as I will start the search .
A few weeks ago the fuse on the starter did blow for no apparent reason and at that time I did have the lights on. Hardly ever go out too use lights but I accidentally hit the switch today and car started actly bad immediately. Turned the lights off and everything was back to normal.
