1930 RHD Tank.
RHD
Christchurch
New Zealand.
Price
450.00
1930 Right Hand Drive gas tank.
In excellent order, but with one defect. The tank clamping bracket has been cut, as pictured. The corresponding part for a LHD could be easily welded to what is there.
The pic of the top of the tank, shows the bottom of the tank through the filler hole. Bright metal is showing. As far as I can see, the complete inside of the tank is the same. Pictured are the tank sides which commonly rust out. These 2 sides are sound.
This tank still has it's original paint and pin striping on the front face. The top has been repainted.
Complete with a good gas gauge which has been removed, cleaned and replaced. It would require a new gasket set installed.
More close up pictures on request.
They don't make gas tanks any more.
