as mentioned above, it will take 2 of you, one to rock the steering back and forth while the other checks every single point for loss of movement. If it turns out the steering box needs adjusting, the procedure is described in the Service Bulletins. Most often, loose steering is an accumulation of wear throughout the entire steering system, although occasionally it can be a result of one thing or another.
