1930 Model A Tudor
Zeke...PA
Delta
PA
Price
13,000
1930 Ford Tudor For Sale - Frame off restored
$13,000
The Good:
new tires and tubes on powder coated wheels, SS caps, the springs disassembled cleaned and lubricated, new shackles, new king pins, new short pitman arm, 4 new brake drums, new shoes, Teds brakes, new brake bushings through out, all new wheel bearings, rear differential - all new bearings and seals, transmission all new bearings, new clutch & throwout, new 6V alternator, spare rebuilt 6V generator, starter & dist rebuilt, new leakless pump, rebuilt Tillotson carb, spare rebuilt Zenith, radiator rodded and repaired, new pistons, rods and rings , new valves, head decked, center main pressure fed.
Body: all steel, new wire harness, cowl patch panels, lower door patch panels, qtr patch panels, rear wheel wells patch panels, new rear fenders. New Cartouche interior, new glass & channels, new roof wood and top, new SS rear bumpers, Trunk mount
The not so good:
Block was not babbitted, rear main does leak, has rear main janitor added to catch any drips.
Send PM
