Hello everyone out there in ''A'' land! I've had my 1930 Tudor sedan a couple of months now and have only driven it about 3 times locally. Weather being most of the reason it sits. It was restored back in '09 and since then the man I bought the car from had only put 1,074 mi. on it. So I thought I'd get it ready for our first Model A meet this weekend and I went and took out the fill plug for the ****** and stuck my finger in as far as I could and felt no oil. So now I'm starting to panic because I have no 600 wt. oil to add to it but I've since ordered some from Mac's. My question is how do you all manage to add oil to the ****** laying under the car with hardly any room to pour the oil in? It's tight. I think I am going to try a turkey baster with a hose on the end of it. I'll probably sit the quart of oil in hot water for a few minutes to thin it out and just try the baster thing. Don't laugh! I'm running out of ideas. I am going to jack up the car and put 4 jack stands under it so hopefully it will be high enough off the ground to work under there. I wish I could drive the car to get the ****** oil hot enough but I don't know how low it is. As it is I wonder if any damage is done to the bearings or gears. I also checked the diff.and it is ok but I might just change it and that way I'm starting out fresh. If you could offer any advice I'd sure appreciate it. thanks, Jim
