evobuilder
I have a 1930 Model A frame fully assembled, running car.... I want to replace the nuts/bolts on the side of the frame that holds in the front cross member (side=facing the wheel) and was wondering if I can simply remove these bolts to replace, or am I dealing with sprung issues? Meaning.... as I loosen, is the cross member and the frame rail going to separate . The reason I need to remove all side bolts (x2) is that I need to grind off some super ugly welded shock mounting brackets.
So, the simple question is.... if I remove all side nuts/bolts from the core support/frame rail, what should I expect to happen?
