1930 Model A CCPU Fenders
A-Man
I will need to be looking for fenders for my 1930 Closed Cab Pickup. Are the rear fenders unique to the pickup only, or will other Model A fenders fit?
Same question but for the front fenders.
Thanks.
i belive they are same as coupe fenders? only widebed fenders are unique..some one correct me if wrong
Yes, coupe and pickup fenders are the same with the exception of the wide bed which uses a rear fender which is about an inch or so narrower. Wide bed rears are harder to find but coupe fenders can be made to work if you take a section out of the middle and weld them back together.
It's more than just taking a section out of the middle to convert a coupe rear fender to fit a wide bed. where the inside bolts to the body is different,the cutout for the splash apron is way smaller and you have the usual trouble re-welding the bead on the tail. on the narrow bed pickup, the taillight is mounted under the bed corner while the coupe, etc, have it in the fender. That's the only difference.
