1930 model a burps
chrisgurga
New member
my all stock 1930 burps into the over flow everytime i drive it ill get back and it belches into my overflow jug is this normal ??motor has 5000 miles on a warren paul rebuild reset timing has smoother power still burps and ideas thanks chris@gurga.com
How full are you trying to keep the level??
The stock model A is very good at getting rid of excess fluids, on my car if the coolant is filled above the baffle it will spit it out till it gets to just below the baffle---then the level stays there for a long time, same for the oil---if the level is above the bottom of the "F" on the dipstick it will spit out the excess oil
