Remember, most wire terminal pliers have little threaded holes that are used to cut off or shorten common screws.Your headlight adjustment screw is coming in contact with rear of the bulb socet and shorting it out, when it is screwed in too far. try a shorter screw to see if you can get it focused properly.
