- City
- Escondido
- State
- Ca
- Price
- $4800
1930 Ford coupe/roadster project…All steel body and parts which include rumble seat brackets,suicide door latches,bolt on or weld on(your choice) headlight stands,1934 Ford headlights,good 4 row radiator with no leaks.GM 10 bolt rear end with wheel spacers,NEW old chrome dropped front axle with tie rod and drag link with all tie rod ends,rebuilt Corvair steering box,,hair pins,bat wings,perches with lower shock mount attachments,Chevy spindles with king pin set and bearings and bushings,cross over spring,new 1932 grille shell with insert,stock dash and gauge cluster panel,windshield with chrome stanchions,nice deck lid,new floor panel,seat frame with donor seat,,chrome dual master cylinder with new aftermarket pedal assembly,Hurst style cross over engine mount with attachment brackets and pads.Car has an original roadster cowl section,a 1930 coupe rear section with modified doors,steel rear fenders.Local delivery available,if needed.No papers. 760-717-1334
