1930 Ford Pickup
rcranger
ilion
ny
Price
6600
project i bought last year to run it as a stock banger truck ,but after second failed knee surgery getting knee replacement sometime in july, so driving this is not going to happen for more than a year, would consider trade but must be automatic,nowhave 5 35 wire wheels two with new 6.00 16 tires, old stromberg downdraft intake and rebuilt ford carb,late C diamond head machined with .125 off ,adjustable lifters ,regrind b cam,rebuilt B water pump,converted to 12v 1 wire alternator,smaller pulley on alt to spin it faster,new battery,mechanical brakes had been redone when i had bought it,pulled the plywood out of the bed that was in it ,replaced with cherry boards and bed strips that we salvaged off an old military truck,have the tailgate it will need i hinge, bottom is broken off one side,stripped roof off was going to have a snap cover made to fit over the opening,so it could run open topped, replace top bow, winshield is good tipps out rear glass replaced. no side glass ,1 regulator in pass door,going to need some finishing will make a great truck ,willpost more picts tommorow and vid of it running
also T rear spring installed,converted to 14mm bosch plugs ,running mallory voltmaster coil
