1930 Ford Coupe Project needing completion
fordtrk56
Temecua
Ca
Price
10750
1930 Coupe Chopped,Channeled,Suicide Doors.....350 with double hump heads,aluminum intake,not running but does turn over,350 auto-histories on both unknown. New wiring harness but not installed,Hurst saddle style engine mount with new rubber pads and mounting brackets. Chopped 3 ½” with rust free body, channeled 4”.Working suicide doors with bear claw latches installed. Subframed rear suspension and notched with new 4 bar, panard bar plus new adjustable coil over shocks.Complete rebuilt 8.8 rear end, powder coated housing and backing plates.New aluminum fuel tank mounted in trunk with powder coated straps to secure it.New Pontiac taillights.New Vintage dropped and drilled front axle with new spindles,bushings,calipers, rotors,shocks,rubber brake hoses,steel brake lines,2 residual check valves,forged lower front shock mounts,stainless front spring perches, 4 bar hairpins plus attachment brackets,tie rod and ends,New Corvette dual master cylinder and pedal assembly with new proportioning valve,New 1932 powder coated grille shell and insert,aluminum radiator,inner fender panels,Mustang bucket seats.New powder coated Halibrand style wheels with new B.F.Goodrich T/A radial tires.Rebuilt Vega steering with joints pitman arms drag link tie rod mounting bracket heim,customed 1932 dash panel,powder coated head light buckets with lights,vented sun visor.All interior window moldings.New Flaming River chrome tilt column with column shifter,new 6” powder coated column drop,new roof wood,new trunk lid with new custom mounting brackets..Lots has been done with all new parts plus I have more new parts to finish the job to make it a nice Hot Rod…Current NonOp title in my name..Local delivery in southern California(Los Angeles south)..Call or text for more info.More detailed pix available, if needed.
760-717-1334
