My early Victoria Coupe (#4554) was built in November, 1930, even though it's considered a 1931 model, as were ALL Victoria Coupes. And mine is early enough that it can be still be called a Victoria COUPE. Ford dropped the word "Coupe" from the name sometime in 1931, if I remember correctly. Mine has the upper insert in the radiator shell and the remnants of paint indicate it was black, although there is no way of telling what color the body was originally. I understand that all Victorias - except the little-photographed prototype - came from the factory with the so-called "Deluxe" radiator shell, which eventually became the "standard" shell for passenger cars in 1931 - but not right away in 1931. It's been a while since I immersed myself in Victoria research or restoration, so I hope I am quoting the facts correctly, albeit not exactly adhering to the poster's Deluxe Phaeton question. The two body styles, however, do share some commonalities, including all wood framing and low production numbers. The DP wins out there, though, by far.
Marshall
