Bill Cilker
A friend and I have been helping an older club member get her 1930 Deluxe Coupe running and, on the road, again. She has owned it for 65 years! When I got in the car to try and start it, I found the steering wheel was very loose, and it would move up and down more than one inch at the rim.
We returned last week to change the oil and tighten the steering wheel nut. Her Model A has a replacement “Easy Steer” steering box in it. I removed the horseshoe clip and slid the horn rod up to get to the steering wheel nut. When I tightened the steering wheel nut (4 or 5 turns), I could not turn the steering wheel. I then loosened the nut 3+ turns and was able to turn it without any resistance. I discovered that the back of the steering wheel was pressing on the top of the quadrant of the steering column tube. The bottom of the column is seated on the “Easy Steer” box as far down as it will go. The steering shaft is about 1/16” +/- short of where it should be.
My friend and I do not want to remove the steering box or change it to fix the issue.
What suggestions do you have to fix this problem?
