1930 coupe top wood
sidevalve
My friend just ordered a top wood kit for his 1930 coupe and this came in the kit.:confused: I told him I thought it was in the kit by accident.:rolleyes: Can anyone identify this?
ATTACH]85747[/ATTACH] top wood.jpg
That is the mounting block for the dome lamp. Deluxe coupes had a dome lamp. That block goes between two of the bows and is held in by screws through the bows into the block. The open end is where the wire goes , through a hole in the bow. If you are not installing a dome lamp, just delete the block.
It is part no. A-13779-W, dome light wood block for the overhead dome light which came with the Deluxe Coupe Models, which also had factory installed cowl lights.
