- City
- georgetown
- State
- tx
- Price
- 17,000obo
30 roadster, clean title in my name as a 30 roadster.
Front end- A axle dropped 4 inches, 40 split bones,tube shocks, 36 ford drums, 48 baking plates modified to work with the 36 drums, all new brakes, 53 f1 steering box, original 40 ford steering wheel. 36 ford rims and hub caps 4.75x16 new black wall firestone tires.
Engine- 53 flathead rebuilt, .060 over, schnieder 3/4 race cam, Navarro high compression heads, navarro 3x2 intake with 3 rebuilt stromberg 97's with progressive linkage, chrome power master one wire generator, mallory yc distributor, speedway headers, walker radiator
******- rebuilt 39 trans, new clutch, throw out bearing
rear end-model a rearend, close driveshaft, 3.73 gears, converted to hydraulic brakes, new brakes, 36 ford rims and hub caps,brand new 7.50x16 firestone tires
body is all henry ford, needs new windshield frame the old one is rusted out. doors open and close good, rumble seat decklid, car has the usual rusted spots inner quarters, little on the cowl sides and lower quarters, rear subrails are gone, body has been rienforced with 1x1 and 1x2 tubing and is good and solid. all new wiring, stewart warner gauges, wood flooring, original speedometer works. uses original gas tank, new battery
f1 pedal assembly, 48 ford master cylinder
car needs interior as you can see in the pics.
asking price is 17,000 no trades, need cash. car is located 25 miles north of austin, tx. for more pics or questions please call mike at 805-748-5213
