1930-1940's rear window garnish ID help
Bustingear
I have what i believe are some ford late 30's 1940 ford rear window garnish moldings but i am perplexed as to what years and models they fit.
1. One is the removeable center piece . It has 10 screw holes in outer ring and 2 in center piece. The two top holes are 8.5" apart, Dimensions-14 3/4" tall and 33 3/8" wide
2. The second one has the fixed center piece. It has 12 screw holes including the center. The two tp holes are 13 1/4" apart. Dimension are 14 3/4" tall and 33 3/8" wide.
Can anyone set me straight on these with year make and model? When i check ebay there appears to be a couple different shapes involved , Some are flatter on the bottom and these both look to be more oval . Thanks in advance.
