1929 Windshield Post Side Garnish
GT1929
This is on an AA Truck it appears that to install these inside I have to cut out a piece where the top hinge is located in order to fit them home. Has anyone had to do this?
are you sure the moldings are for a Model A not Model T. the T`s look about the same but taller.
Your closed cab is type 82-A (same as used on the A-chassis). The finish strips you reference must be installed before the windshield female hinge and before the front belt rail finish strip.
Hello,
There came with the AA I'm sure there Model A. I did find pictures of some on net with this portion cut out at the top.
