1929 Tudor
IGotIt
I seem to have a problem where both high and low filiments ane burning at the same time. Ive checked my wiring out but I can't figure out the problem.
Any advice?
Thank You
Probably the terminals in the sockets are rubbing together which is a problem with the repoduction sockets. I put a piece of plastic drinking straw around each terminal to keep them separated. You need to cut the straw length so when the terminal is compressed the straw isolates it.
