UPS Driver
Steering box is a little bit loose and I’m wondering what I have it’s marked Gemmer 2 or 7 tooth
Also when I turned on headlights the ammeter went into a 10 amp discharge ( has a NU-Rex 6volt positive ground alternator) belt probably had an inch inch and a half play VERY loose is it possible this is a culprit for a no charge problem? Thank you to all for the help !
Brian
Brian
