rackops
All:
My second post on the forum!
I'm looking for some opinions/advice on my engine. Here's some background...I bought the car over a year ago and it was beautifully restored. The restoration was completed about 15 years ago, and the engine was rebuilt at that time (I don't know how well it was rebuilt, but it did run really well).
Well, just recently (about two months ago) I noticed that it was leaking radiator fluid out the sides of the head. Not much, but enough to start the paint peeling off the engine.
I also noticed that the engine was running rough, with an uneven idle.
I figured I had a bad head gasket. So, I pulled the head and replaced the gasket with the "deluxe" gasket that you can buy (why skimp on a $28 gasket???) It took me TWO DAYS to get the darn head off (the last time I pulled a head, it was on an engine that had NEVER been touched in 70+ years and it took me 3 hours to pull it...)
I got the head off, cleaned it up, replaced the gasket, and put it back together. No more radiator fluid out the sides...check. BUT...still had an uneven idle and the compression (though not checked) seemed low...the car just seemed underpowered and had very little "pep".
AND - to make it worse, I looked at the back passenger-side head stud and noted that it was wet on top after running for about 30 minutes. What the heck??? Then I noticed that there was radiator fluid leaking THROUGH the threads between the stud and bolt! WTH??????
Talking to my dad (not a model A guy, but a military vehicle guy) he thinks that I may have a warped head. Exactly a year ago this month, I was in a parade and the car overheated. I had to limp back home with it spitting radiator fluid down the road...ouch! He thinks that I may have warped the head then, and maybe caused other damage.
So my question is this: Could it just be a warped head? Or could it be something worse? I don't mind pulling the head and buying another one for it. I'm loathe to pull the engine and have it rebuilt to the tune of $5000 if it's just a warped head...but at the same time, I don't want to drop $300 on a new head and the time to pull the old one if it's not going to fix anything.
Any thoughts/opinions out there????
THANKS!
Dave
THANKS!
Dave
