1929 Model A Sport Coupe
Gasserdriver
Oklahoma City
OK
Price
$15,000.00
I am listing this 1929 Model A Sport Coupe, new build with 500 miles since new for John's Hot Rod Shop and Museum, 1-405-396-2055 after 2PM.
Coupe is chopped 2.5 inches, all new wood, new tinted glass, all steel (no fiberglass), mitchell overdrive, Antique engine rebuild with balanced crank, inserted bearings, larger valves, New highest performance cam, lightened flywheel with V8 clutch, Miller high compression aluminum head, FS electronic centrifical distributor, new gears and bearings in transmission, Model T rear spring, all new bearings in rear axel, frame double plated and cross braced, dropped front axel with all bearings and bushings new, 12 volt system with alternator, aluminum radiator with electric fan, 16 inch 1935 ford wire wheels with new tires front and rear, also a pair if 1934 ford 17 inch wire wheels go with car for front, custom auto sound radio, Tack, GPS system, Model A sedan seats with seat adjuster, rear mount 11 gallon fuel tank with electric pump with regulator, Weber 2 barrel carb, Reds headers, glass pack muffler.
Those of you who know John know he does all the work himself, paint, bodywork, interior. He sends nothing out. Every inch of this A has been messaged, the under side looks as good as the exterior. This car can't be built for $15,000.00. Call John after 2PM at 1-405-396-2055, if he does not answer please leave a message and he will call you back. Thanks, Fred
