1929 model a motor, short block
zzlegend
Reseda
ca
Price
100.00
Here is a 1929 short block motor. Supposedly ran very decent when removed because of the typical freeze crack in the front of the block. See pictures. If I were to keep it, I would braze it up or JB weld like so many do. It has 015 pistons in it. The cam should be replaced as it is pitted. Both cam and crank gears should be replaced due to pitting and a couple of nicked teeth on the cam gear, from moving it around. Might need some new head studs or just replace the missing ones. The numbers show it being a August 1929 engine. No other parts with it. Just what is shown. Look at the pictures and see if you can use it. Pick up only.
