1929 Model A coupe for sale
Tom Endy
Westminster
CA
Price
$13,500
1929 Model A Ford Standard Coupe (July 10, 1929)​
Engine:
The engine was rebuilt by the previous owner in the 1970's and driven only 200 miles. In 2004 it was removed from the car and disassembled for inspection. The pistons are .080 over standard. The crank is a Model A crank with Babbitt bearings.
The following was done to the engine.
* 5.9 Brumfield head
*“B” grind cam with a aluminum timing gear installed
* Hardened valves, valve springs, and adjustable valve lifters installed
* flywheel was lightened by 12 pounds and balanced with new clutch
* Float-a-motors installed
The following was done during the re-restoration, 2004:
*Hydraulic brakes (restoration of existing 39-41 system with a Cling kits
*12-volt alternator and battery
*Rear-end rebuild (378 gears)
*Transmission rebuild
*Bell housing and pedal rebuild
*Ryan overdrive installed
*Distributor rebuild, Zenith carburetor rebuild
*F-100 steering box installed
*“A-Fordable” oil filter system installed
*Aires Muffler installed
*5-brand new tires and tubes. Wheels repainted
*New upholstery
*Seat belt installation
*4-shocks rebuilt
*Radiator rodded-out\temperature gauge installed
*“Leakless Rupert” water pump cast aluminum 2-blade fan
*LED taillights and third light
*Parking brake release installed
*Trailer hitch, 31 style column support installed
The car is an excellent daily driver
Tom Endy 714-897-5861 tendy@socal.rr.com
