rembrandt78737
Was having overheating issues with my 1929 Fordor, so I bought a new leakless water pump and a heavy-duty radiator (among other fixes). Now that I've started the installation of the new radiator I noticed the fan blades are barely clearing the upper hose (approx. 1/8"). I'm using the stock 1/8" pad for the radiator. The issue appears to be the upper neck shape on the new radiator.
The old radiator showed evidence that the previous owner forcibly reshaped the neck to offer more clearance. Before I attempt some kind of fix I need to know how much clearance I SHOULD have from the top of the fan blade to the upper radiator hose? None of my Les Andrews maintenance handbooks address the issue.
