Well Miles from the Ford Barn dropped off his coupe today !! Needs some subrail work patch panels.rust holes and probably a few other things im looking over!! The car has a ton of family history for him and i cant wait to get it solid again for him
I don't weld panels.. I burn holes. I couldn't think of a better man to pass on our project to keep it going. Flop will get it in order and fix my screw-ups too.
Between a 120 mile commute each day, starting a new full time job and helping out with with the father-in-law I had neither the time nor the patience to keep at it.
It'll go back together better and faster than I could make it happen.
well just got back from a big vacation/work trip . wisconsin to work on a 40 merc convertible then to austin texas for the lonestar round up!! just got back today and decided to do some work!! man it feels good to work in my own shop again. gonna start on the cowl and work my way back .
a little rot to start off with
a patch panel for the most part that actually fit . i didnt use the beak in the front though it was crooked where the model orig was actually straight
after a little tig welding and some hammer and grinding
Hey Flop, nice work but make sure you assemble the sub floor on a jig or a good frame for mounting hole alignment. I just mounted a pickup body that was repaired by someone else and the right side mounting holes were 1 inch forward of the left side, had to use a portapower and the rails broke apart while trying to line up. We ended up mounting then rewelding the rails in place. Those frame holes are the boss.
good tip barry!! i have the 30 roadster on that jig now so getting these lower subrail pieces sitting in is about as far as i can take it for the time being.
well everything was going to smooth....something had to not fit right.
repop subrails are the culprit!
as you can see the pad where the subrail connector rivets to the inner connectors isnt even close . the orig connector had a step in this area to move it back the 3/8 of an inch so the pieces mated as you can see in the pictures.
well apparently there are no repops made of this connector from the door post to the cowl so i had to whip up 2 of em .
heres the first side. they resemble the original but the og pieces have a shape pressed into them . i cant get the shape pressed into 16 gauge plus they are never to be seen again once the car goes back together
