mullskull
- City
- LA
- State
- ca
- Price
- $200
recently i acquired a rolling chassis...everything is pretty rough.... it was a Texas car, that seems to have been sitting a long time- i took what i need, now i'm looking to unload the rest-
Engine # A3155944 (OCTOBER 1930??)
the engine is frozen(bores are soaking )maybe it'll free up??
has distributor, generator..fan, both manifolds..and carb, as well as the front mount, and pieces of the throttle linkage-
Trans- turns free, shifts into all gears, i pulled the shift tower off and looks as it should.. no rust and filled with oil..
Rear end and torque tube- turns free
misc. parts- front fender braces(stamped), lever shocks(some frozen some not), rear bumper brackets(parts attached to the frame.) side engine mounts(one is cracked)
brake hardware front drum and backing plates.right front drum frozen(linkage rods, cross arm, brake switch....
a set of mismatched wire wheels(i can measure if ya really wanna know)
$200 or make me an offer....
local pick up only-
rich 323 379 8421
local pick up only-
rich 323 379 8421
