mach0415
I recently posted, concerning banger compression. I wanted to post, concerning rod bearings and pistons in a new thread. I Flipped her over about 45 minutes ago and pulled the pan. Seems like I need to clean her out good. Some sludge at the bottom of the pan and grit. I inspected crank and rods. Looks to be good. I need to take some measurements. At some point a rebuild was done, because there are remnants of slag splash on the rods and caps from a re-babbit pour. The rods and caps have been marked with punch dots for each associated cylinder number. I pulled #1 and #3 piston and rod to inspect bores and piston rings. Rings are free and bores look ok, but not perfect. No significant scratches, but some very minor rust "bruising" but no pits. Would you guys recommend honing and reringing it? Also, the pistons say "Mcquay-Norris" on them and have a full-length split skirt. Any light to shed on that? I have not checked specs yet, but on the tops of the pistons it says "P15"
