I found the local model A club in Ottawa.
Ok I timed it right this time, did it while on the phone with club organizer.
He sent some stuff about timing and I'm looking at what you guys are saying and my timing was off.
It's good now
Thanks for that guys.
Now if I try to start it the right way I get nothing and the carburetor is spraying fuel in perfect rhythm with the engine crank.
Except it's spraying out the hole on the bottom of the carburetor, if I remove the air filter it sprays out of the opening of the choke plate.
It looks like the spray I should get from the carburetor but it's going the wrong way.
If I give her a little more throttle or some choke when I'm trying to start it I get a backfire in the carburator
I can see the smoke from the backfire come out the carbs vent hole or through the hole at the bottom.
Wow is that ever scary when it backfires in the carburator so I'm a little reluctant of cranking for a long time.
It's good now
